i agree with most of this. but the coarse knob is way too touchy to use to tune people in.From what I recall you can remove the detent in the coarse tune on any radio by carefully opening up the switch and removing the ball bearing that sits in it, was often done to Cobra 148 GTL DX and SS3900 amonst many others here, although personally I don't see the need, tune the radio once its preheated for about 45 mins, make sure fine is set dead centre while doing so and use the coarse to tune anyone.
Soon as you start using fine receive only clarifiers you will run into problems as soon as you have more than 2 stations on the same frequency, if everyone locks on with coarse tune then they will all be transmitting and receiving on exactly the same frequency, and anyone joing should do likewise, if one only has a fine tune/clarifier then everyone should use coarse to tune into his tx frequency, if he clarifies one, he clarifies all, its not rocket science, wee've been doing it here since 1980,
only fannies that have to see 27.555.000 on their display would worry about being a tad off frequency,The biggest irony being those with the readouts that say 27.555.000 are rarely actual frequency counters and are more displays, so it is very very critical they are set up properly to read bang on frequency, and most of these type of Morons are the local who's radio is the frequency standard all others should be judged by, fucking laughable,
even radios with .5ppm tcxo are allowed to be +/- 54 Hz and still be classed as bang on frequency under manufacturer specs, that's why these radios have vfo's and RIT's a posh name for a clarifier, no two sideband radios will ever be the exact same frequency and all drift no matter how small or large the drift is. That's why you get frequency stability specs, I ain't seen. Radio yet that don't drift at least a few hertz from cold to warm with a decnt accurate counter and you may need 8 digits to see it but more often than not you'll even see it on 7 digit counters.
All this my radio doesn't drift pish dates back to the days people had 5 digit counters and couldn't see any drift less than 1 khz.
i have my 3900 with both clarifers married together and just use the fine nowhere near
as touchy, and best of all only 1 clarifer to use as fine does both tx/rx
