No noticable difference. I did note that as I was testing SWR, my neighbor across the alley using his plasma cutter, I could hear when he pulled the trigger to cut.
I'll snap another on tomorrow.
Well, I have noticed the fuel pump and ECM noise is not as noticeable. Now, I have clear receive until I hit around 50-55MPH, and it starts sounding garbled, like someone is talking thru water. I have put the spring back in the antenna, put a DXE snap-on ferrite about 6" from the base of the antenna, and connected the Texas Star 250 (has auto SSB) into it. I also put a braided ground strap about 4" long from tailpipe to frame, basically using it to jumper across the rubber hanger about a foot or 2 from the end of the exhaust.What’s the latest?
Where is your RF ground? It's literally the top surface of that box section of steel the mount is bolted into, that's it. You have none, regardless of what you measure with a DC multimeter - I bet if you were to connect to that antenna using an antenna analyser with a short bit of coax and see what the value of R was when it got as near to resonance as it'll ever hope to be that it's dozens of ohms away from the perfect ground reading of 36.8 Ohms.You have an antenna with no metal under it, mounted low to the ground, an inch or two away from adjacent metal for the part of the antenna where the highest RF current flows. The only way it could be made any worse would be if it was stuck out from the vehicle on an arm bolted to that bracket. You would do much better getting a shorter antenna such as a 6ft Sirio and mounting it on the fender. Yes it'll be directional but so is what you have now but it'll work a whole lot better.
Until you relocate that antenna you'll never solve the problems. You cannot solve the issues where it's mounted.
That always calls for a fresh bottle of gin. The season for an icy Tom Collins is still with us.
