  • The Retevis Holidays giveaway will happen December 31st! Check Here for more info!
Modified Washington with unstable clarifier
I'm back on this one today. The channel kit has been totally removed and the instability was still there. I have shortened 1 wire going to the clarifier by 1 inch and it seems like it is fixed. I still don't trust it.
Reactions: brandon7861
Simple test. After squirting cleaner into the clarifier and rocking the knob end-to-end, what it does the next day is important. Tune in a steady carrier and lightly tap your fingertip on the end of the clarifier knob. If you get a response, that control has probably just deteriorated. If it holds steady, it's okay.
A fault that's mechanically sensitive to tapping anywhere in the radio can be a hair-puller to track down.
Reactions: Enterprise312ok
  • @ unit_399:
