Why are you installing the HF antenna ABOVE the satellite array? Convention says to do it the other way around. The azimuth rotator turns everything and the elevation rotator is mounted above the HF antenna and elevates just the satellite array. You also do not have the satellite array firing through the HF antenna that way. Any pix of the existing satellite array and rotator assembly?
Well Change 23, I found a used rotor tray for the tower and have disassembled everything. The Satellite array will be on the very top and the beam about 4' below it. No Gin pole requires a bucket truck to make it easy and he wasn't suppose to come till Tuesday so I redesigned the whole thing. I'll take some pictures tomorrow and as things progress ...
