Might have relocate to NJ due to job and current housing BS with my sister here in NY arguing all the time. Most houses are very close. Most are 2 1/2 story type. Yard is very small at 14x25 (guess). House in NJ is middle house (nice having a drone). I was thinking the notch in left top corner and run a 20' mast straight up in that corner where brown roof is or just put up a post in middle of back yard. Again 20-25'. Antenna is my A99.
The first brown roof is an attached pantry. The second is the screened in porch area. That little notch is part of the house and I have easy access via side screen door. Was thinking post there attached with standard 4" mast standoffs. I was thinking in that area and not near main house(s). I would run coax up high to get to it. It would be 2 top rail probably bolted together. First top rail top would be about 2' above roof and then other rail would be only one over with A99 on that.
Thoughts.
My HF is easier as I have an end fed.
Thoughts.
