Yota said:Hey DRM, Did you read this in my post...Know mind you I have had other antennas too, I have a Super Scanner, Super Penetrator, Imax 2000, Antron 99, This thing Smokes them all !! This Antenna it 25 feet tall, You can go Taller if you need to there is the room.. It has 9' ground radials makeing it 18' feet across on the Ground radial..36' in Ground lenth alone !!
yeah i read....you stated you "have had other antennas".... you never said you directly compared them side by side....
Yota said:I have run a Few other Antennas, And this is far the best I have ever used. Yes I have a local here in Nashua NH, Named Reggie That has had Problems tunning his Antenna. I have not been involved in tunning it. But if you spend 300.00 on a Antenna and what to be a Mudduck, that is not my Problem.
if he had tuning issues why not contact jay???
Yota said:I have heard all types of wonderful things about Jays antenna I have !! I almost bought one, But wanted a Enforcer after I did my home work....
could you explain what you learned or what specifics of the enforcer .64 that makes it capable of outperforming a i-10k???
Yota said:This is a forum to be inform people on products good or Bad.
it's not good to mislead people either.....so why add info that hasn't been proven as factual information???
