judging from the two prior replys thats not quite correct. but then again i was the one who asked the question.
linearone said:you're kidding me right?
this is a joke right. you cant seriously be running around like that.
NorthStar said:linearone said:you're kidding me right?
Now we've seen it all Greg. Haha
Drifter said:I see that palomar going poof if he forgets which of those two red power wire is possitive and which ground. :shock:
DJboutit said:Both antennas are hot have not noticed any better direction
SmackDown said:DJboutit said:Both antennas are hot have not noticed any better direction
I asked the question previously because the spacing between the two antennas even if the setup was radiator and back door seemed small. Your reply that both antennas are hot means there's a co-phased arrangement, am I correct in presuming this ? Are you using a co-phase harness ? (75 ohm coax) Have you used a field strength meter ? Does your setup radiate stronger north-south or east-west ?
73's
DJboutit said:SWR is about 1.3 to 1
