I've got one of these up 21ft off the ground at the shack, and have been using it for 11m use the last couple years....coax I'm using 50ft of RG 213 and also a 12ft of LMR 240 coax on it....yea I no I needed to stay with one type of coax but this was something I didn't plan on doing.....( my Imax has just been at the shack for a little over a year now, that's all )......but it works good....
On the 11m band the swr is setup to be lower on the high end of the band, so from channel 10 and below channel one the swr runs a 1.3 to a 1.5....and from 27.2050 up through 27.6550 the swr runs a 1.2 or less, and the swr goes up a little around 27.7050 to 28.200 swr runs around a 1.5 to a 1.7....and at 28.3250 through 28.500 the swr runs a 1.2 to a 1.5....
This is what it was running at the last time I checked it when I was running a 2995dx...and both the rings are in the center of the black together...
I ordered a FT 450d, when I get it I'll check the swr on the 10m bands I do hold a Tech lics here, and do plan on up grading to my General soon as I can...
As far as the antenna goes, nothing has been moved the rings are still in the middle of the black, oh yea all I have done since its been put up here at the shack is added the 12ft of 240 coax, that is because I didn't have enough coax to reach the shack, other than this nothing has changed since I bought it new and set the swr on it......so, the swr all should be good on the 10m band where I set it up at from the first, right ?....
