Hello, My Handel is RollingStone and I could use some help and also might be able to offer some help.. I have a new old stock "Single Engineering" SuperHawk/Lighting antenna, it can be assembled as 2 element Quad (Superhawk) or a 4 element Quad (Lighting).I don't have a signal engineering patent per se, but if you check the US Patent site you can look up US 4236160 A, the patent for the loop driven element antenna system and voltage feed system. There are images that look just like images in the SE manual.
I'm not sure if the New owner of SE makes the kit the same as the original however.
https://www.google.com/patents/us4236160
However I do not have the instructions.
All the parts that I have are new and can be measured precisely if you are interested in this info?
FYI, I am looking for assembly instructions? Something seems funny in the math.
I would appreciate any info on the SE antenna's
Thank you for your consideration.
