NICE CK!! ENJOY
NOW HERE'S MINE
2012 SILVERADO LT CREW CAB Z71 4x4
ALL STAR EDITION
5.3L V8 VORTEC/ 6 SPEED AUTOMATIC or (5 speed push button manual when heavy towing)
TRACTION CONTROL
4 WHEEL ANTI LOC
TRAILER PACKAGE/OVERSIZE RADIATOR/ OIL and TRANNY COOLER/ 145 AMP ALTERNATOR...etc...
Drops 4 Cyl in overdrive....Drove to FINDLAY,OH Hamfest Sunday...
390 miles round trip
Avg 17.7 mpg...Avg speed 68 mph....Love that!!!
All the Best
Gary
Here are the dealer specs on the vehicle I
bought. It has a few other things that are not listed as well like an engine oil cooler, transmission cooler, and even a power steering fluid cooler. It also has a six speed automatic transmission with the ability to manual shift it bu bumping the stick forward or backwards,traction control that can be turned off,all terrain tires,heavy duty battery,starter and 170 amp alternator and a few more things I forget about right now.
2012 Toyota Tundra SR5 5.7L V8 Truck Crew Max Cab
Features
CONVENIENCE FEATURES1-touch downDriver vanity mirrorTilt steering wheelAuto-dimming rearview mirrorAir conditioningGarage door transmitterFront beverage holdersSpeed controlIlluminated entryRear door binsFront dual zone A/CTelescoping steering wheelRear beverage holdersPower windowsPassenger door binRemote keyless entryOverhead consolePassenger vanity mirrorDriver door bin ENTERTAINMENT FEATURESWireless phone connectivityMP3 decoderAM/FM radioSpeakers: 6Steering wheel mounted audio controlsCD player SEATS AND TRIMRear seats: split-benchRear seat centre armrestPower driver seatSplit folding rear seat WARRANTYBasic warranty: 36 months/60,000kmRoadside assistance coverage: 36 months/60,000kmPowertrain warranty: 60 months/100,000kmCorrosion perforation warranty: 60 months/ unlimited distance BODY EXTERIORRight rear passenger: conventionalTrailer hitch receiverTurn signal indicator mirrorsRear cargo: tailgatePower door mirrorsBumpers: body-colourRear step bumperLeft rear passenger door: conventionalHeated door mirrorsSkid plates SAFETY AND SECURITYTraction controlKnee airbagBrake assistElectronic stabilityABS brakesDual front side impact airbags4 wheel disc brakesPanic alarmOverhead airbagOccupant sensing airbagIgnition disableDual front impact airbags LIGHTING, VISIBILITY AND INSTRUMENTATIONOutside temperature displayTachometerOil pressure gaugeTrip computerFront reading lightsFront fog lightsVariably intermittent wipersCompassRear window defrosterLow tire pressure warningVoltmeterRear reading lights
Tech Specs
OFF-ROAD CAPABILITYGround clearance (min): 270mm (10.6")Approach angle: 29 degDeparture angle: 20 deg POWERTRAINFuel economy city: 16.6L/100 kmMode select transmissionHorsepower: 381hp @ 5,600RPMFuel economy highway: 12.2L/100 kmEngine litres: 5.7Variable valve controlTransmission: 6 speed automaticManual-shift autoSequential multi-point fuel injectionFuel tank capacity: 100.0LCylinder configuration: V-8Engine location: frontRecommended fuel: regular unleadedTorque: 401 lb.-ft. @ 3,600RPMVariable intake manifoldDrive type: four-wheelNumber of valves: 32Limited slip differential SPECS AND DIMENSIONSCompression ratio: 10.20 to 1Engine horsepower: 381hp @ 5,600RPMRear legroom: 1,131mm (44.5")Payload: 620kg (1,367lbs)Front headroom: 1,021mm (40.2")Turning radius: 6.7m (22.0')Exterior height: 1,930mm (76.0")Curb weight: 2,551kg (5,624lbs)Front shoulder room: 1,692mm (66.6")Wheelbase: 3,700mm (145.7")Exterior body width: 2,030mm (79.9")Towing capacity: 4,080kg (8,995lbs)Engine bore x stroke: 94.0mm x 102.1mm (3.70" x 4.02")Rear hiproom: 1,590mm (62.6")Rear headroom: 983mm (38.7")Front legroom: 1,079mm (42.5")Engine displacement: 5.7 LExterior length: 5,820mm (229.1")Engine torque: 401 lb.-ft. @ 3,600RPMRear shoulder room: 1,662mm (65.4")GVWR: 3,266kg (7,200lbs)Front hiproom: 1,600mm (63.0") SUSPENSION/HANDLINGWheel size: 18"Speed-sensing steeringFront wheel independent suspensionPower steeringFront anti-roll barAlloy wheels
Sorry about the formatting of the specs making it hard to read. The table did not format correctly when copying and pasting.
