am I looking at the pic of the 477 final without a screw and heat sink grease and a insulator on it.
I just ordered one of these to see how it does. I am going to see if AM can wake up a little by changing a couple resisters.
R258 to a 1.5k
R261 to a 3.9k or 4.7k to see if ether will pick up the modulation.
Did that for two reasons:
1) To show the output device and identify its make/model. It also shows that it is a 'blue dot'; not a 'green dot'.
2) To remove/replace the old, dried out heat sink compound. This was also done to the other three devices (driver, voltage reg, & audio IC) as they also had dried out compound. The old compound came off as a dry, flaky powder; which cannot provide any heat dissipation.
There is no problem getting more modulation out of this radio. I can get more than 100% out of it with the mod I did to the AM Limiter. The problem is that it will get negative peak distortion after 100% is reached; as any radio will when the AM Limiter has been removed. Removing the limiter is bad because it has a direct bad effect on SSB TX. So keeping the AM Limiter installed -but effectively disabled- by adding the 1.5k ohm resistor keeps SSB TX unmolested. What is needed is to add the compression for the negative peaks so that the positive peaks/amplitude above 100% can be raised up w/o distorting the AM TX.
