Retevis is giving away Radios for the New Year and Every Member is Eligible. Click Here to see the details!
I'd like to have a model 90. I think that old 135 uses a 90-7. The radio also has the 10 KC slider mod. When I got the rig it had a vernier on the clarifier but it proved to be unnecessary so it was removed.
As it is currently set up the VFO tops out at 27.735 +/- a few KC. Yes it drifts (didn't they all?) If it tweak the tuning cap on the bottom it will go almost to 27.995 but then there is a gap between channel 20 and channel 40.
Not really much of an issue as I don't like getting too close to the 10 M band especially with all that unfiltered sweep tube gear.
@ Morse: I got the map from Wide World of Maps. That map is unlaminated and cost around $38. Laminated versions that are blue instead of brown run around $80.
@KingCobra: Yes, the elevation does help. Even so I am still in a valley surrounded by mountains.
Need help lost my channel chart . Cobra 148 GTL with a 8719 and 11,1125 crystal 26.175 to 28.045 , Need the chart I can fill in the blanks slide 2ck up and 12 kc down
