Need a little help
Sebrina
May 12, 2009
Ok so I'm getting in my new power supply and antenna on Tuesday, but since my setup is anything but ordinary (thanks to my landlord) I really have alot of questions even after reading as much information as I could absorb on the internet. Let me first describe my situation:
- I live in an apartment where I will never have access to the roof, luckily I'm pretty high up but roof access is not an option. I've asked multiple times.
- I don't have a balcony but I do have a window, my windows are aluminum and won't ground anything, there is a air conditioner installed not sure what can be done with it though.
Ok now you more or less know my situation, here are some questions...
1) I ordered a no-ground antenna after realizing I would lose at least 15% power by using a NGP antenna, now ordering another would be fine but what can I use as a ground? Would a magnetic mount work if I put it on top of an air conditioner and are there any drawbacks by placing a cb antenna directly over an a/c?
2) Is there maybe a possibility that I can ground a regular mount antenna by plugging it into the ground hole of a wallsocket? Again what would be the drawbacks and is it possible to burn the house down or something catastrophic this way?
3) I can use a mobile cb antenna of up to 4 feet which mobile cb antenna would work best in my environment? I already have a firestik 4 feet NGP antenna on the way but I'd like to have the best reception transmission possible w/o hitting anyone with interference.
Thanks for reading!
I have used a mag mount LIL WILL antenna stuck to an air conditioner in a window it worked ok, you could even stick it to a large cookie sheet so you could move it around the apt and try it in different locations. Dont mess with the wallsockets ! If you have radiators by a window you could stick it on the radiator or a fridge all these will work but not as good as an outside up in the air antenna .
Well sorry to hear your landlord is not the type to be more considerate ..
I like the cookie sheet...also can use refridge..
Do you have a fire escape..if so can build a mount to go off of it
allowing/enabling you to mount an antenna a couple of ft from fire escape..
I know you said..no way to get to the roof..
Why not offer landlord say $50-$100 to let you on roof for a day ?
Myself...I have 2 chimneys and a vent pipe on the roof...
My land lord thinks i am a bit nuts...but i ran LDF5 & LDF7-50a too roof...going to a HF 5/8 wave groundplane..as well as dual banded GP-9 and 3 beams (1.25 & 2 meters and 70CM)
my 2 verticals are 22-25 ft above the roof (GUYed of course )
You know how the saying goes..
Money talks and B.S. walks
You could make a simple dipole and attach it to the window sill somehow. The magmount idea on the air conditioner is a pretty good idea, though.
Ive managed to tune fire stik IIs to some crazy things. They work pretty good to if you get up high. Id say get one and a mag mount for it and put it on that air conditioner.
Tune it up and you should be good to go!
    535A has left the room.
  • @ AmericanEagle575:
