After 2 years of work my home is finally done and i am ready to finish my radio room and put up a antenna.
This is my situation. I live in an area that is surrounded by mountains. when i say this i mean i can walk out the back door and in about 100 yards starts the incline of a 2000 ft mountain,out the front door and in about 300 yards there is a 1500 foot mountain,It is like this in every direction. Oh,and where my home sits i am 1400 ft above sea level.
Local talking is limited because of the surrounding hills and such so i'm trying to get some kind of antenna set up that will allow me do DX as well as i can. SSB communication on 11 and 10 meters is my primary concern as i dont do the the AM thing any more and will be taking the test for my ticket this spring.
Antenna locations are a little limited as i dont have the room to lay down a tall tower and cant afford a crank up tower.I also have homes all around me from right behind my home to right in front,all family and friends homes thank the lord! So what i have is a 25FT steel well water pipe that i was thinking about mounting some type of vertical antenna to. I could also run a wire antenna horizontal along the top of my house(home is at least 80ft long),i dont have not one tree close by so running it vertical is not an option....unless you have another idea on how to do it.
The question is what would be the best way to go? I have done much research on this in so far as the different antenna types and the construction of wire antennas and needed height for an antenna to work as it should but because of my location, i just dont know which would be the best way to go and i would rather not wast a lot of money trying to figure it out. I'm not looking to talk around the world but dont want to be limited to just the east cost either!
Thank you for any info you can provide me and most importanly,God bless!
