Need Help Identifying Plugs On An ANTENNA ROTOR
Well I just measured the jack on my Yaesu G-2800DXA rotator I have in the basement and it is NOT the same size. Yours measures 13/16 of an inch and mine is only 5/8 inch. Also mine has four key ways in it to ensure proper alignment when inserting the plug. The pin arrangement looks the same however. Also take note that the rotator housing on both yours and mine is flattened where the connector is mounted. A normal flat based bulkhead or panel mount connector will work perfectly. No need for shims etc as the surface is flat and not curved.
Reactions: Dmans
The rotor plug is definitely NOT a microphone plug . . . It is MUCH Larger.
I took some photo's with a ruler to give some scale to it
View attachment 24529 View attachment 24530 View attachment 24531
Looks like a standard encoder plug used in industrial automation. I believe it is made by Amphenol but I don't know if the numbers on it mean anything. Should be able to get it from Digikey. I will dig for a part number. Looks like the threaded part on this one is longer, might have to modify the ring.
Chris
  • @ W4KVW:
