I,m new at posting a thread ! Here goes ...... I have a nice D&A Phantom three stage amp that I,m freshening up ! All is finished but one problem in the keying circuit ! This is the triple stage version ... 4 - 6LQ6,s driving 6- 6MJ6,s with the 6AQ5 tube keying circuit , 2 relay version . I cannot find a schematic anywhere that shows this 6AQ5 tube circuit ! The problem is I did not pay attention to which pin on the 6AQ5 tube socket that the negative side of the 10uf 150v capacitor gets soldered to !!! I believe that I have it narrowed down to Pin 4 (6vac) or pin 5 ( 450vdc ,Plate) ... If I,m correct, this capacitor comes into play with SSB . I have powered this amp up on am only (capacitor not soldered to the tube socket, SSB switch is off) into my Ameritron 1500 dummy load with 4 watts of drive. I have 900+vdc and 450+vdc from the power supply and the amp loaded up 500+ watts with a 4 watt dead key ! Looking like I,m good to go aside knowing where to solder this 10uf 150v cap to the 6AQ5 tube socket !!! Any help would be appreciated , Bruce
