Unfortunately I don't have a dummy load other than the one on top of my neck. You are 100% correct JJ. That would have narrowed things down. I'll order one now. Though I already ordered another 75 foot run of coax so we will know once that arrives.Disconnect the coax from the antenna, and attach a dummy load to the antenna end of the coax. Fire up the radio and check the SWR. If it holds steady, the coax is good and the antenna is the problem. If the SWR goes up, the problem is the coax. Either way, you solve your problem.
- 399 J.J.
