need info on how to modify a sirio sy27-4 for 10m
Ehm..
With the knowledge provided after research.
Another thing will spring to mind....
You can find out there are manufacturers out there making delta loop antennas
Where they model them using for example a eznec + version using a nec2 engine.
The delta loop excist out of two heavy duty inch pipes pointing upwards and a top wire between them. Hence large diameter difference.
Now, do yourself a favour.
Model a single delta loop with those diameters and test them in NEC2 and MININEC.
You will see NEC2 is not capable of handling that accurate.
The manufacture has spend money on software that looks "nice", but he might consider using Mininec for his application.
Where it is perfectly possible to design a multi element delta loop with 50 ohms impedance the manufacturer will "stick" to his gamma-match simply cause he doesnt really understand what is going on.
Isnt it addicting to find out how and what is going on ?
Kind regards,
H>
Reactions: tecnicoloco
    Greg T has left the room.
  • @ Galanary:
