I decided to add some power to my Galaxy DX959 and my pyramid only dished out 10 amps continuous and wasn't even close to the peak 34 amps I needed so I started looking for a worthy power supply for a decent price, after much research the best unit I found for the money was the new MegaWatt model # S-400-12, it puts out 10 to 13.8 DC volts by adjusting a small pot on the front and can run on either 115 or 240 volts ac. The power supply is housed in an aluminum box and is amazingly small and light for the power it supplies, I was a little sceptical until I hooked it up, using a volt meter I adjusted the voltage to 13.8 volts and hooked up 250 watts to it, the power supply worked great with minimal voltage drop at full power output with no light dimming, after awhile of operation the regulated built in fan came on and is very quite, the power supply is rated at 36 amps at 90% power and 30 amps at 100% power continuous. It came with a 3 prong power cord that you attach to the front terminals and the cord has a built in on/off switch, It also has 3 plus (+) terminals and 3 negative (-) terminals for hooking up your radio and other accessories. So far I am very impressed with the MegaWatt S-400-12, I purchased it on ebay for $67.00 and that included shipping to my door. I could not find any other power supply that was in the same ball park for under $150.00 shipped...
Pros:
A lot of bang for the buck.
High amp output with low voltage drop.
Built in fan with thermostat
Quite fan.
It's brand NEW
Newest technology
MFG Warranty
Con's:
No provisions for mounting/bolting unit down.
Being light it slides around alot.
Power cord attaches to the front of unit so the cord's sorta in the way.
I don't really like the on/off switch on the cord and would have been happier if it was built into the power supply.
Overall if your on a tight budget like me and need alot of amperage for a low cost ($67.00 to your door) this might be the ticket for you. So far I am very pleased.
****Just a note, if you look it up on ebay make sure you get the MegaWatt Model S-400-12 as the 12 mandates 12 Volt, I saw one just like it but it only put out 5 Volts. = Badland61 waving at ya from the Great Northwest=
Pros:
Quite fan.
It's brand NEW
Newest technology
MFG Warranty
Con's:
