It's very nice. I am only running it on 110v for now, and seeing 1000 out on 40 meters. I have 220 ran now, and will convert the amp when time permits. It runs just barely warm when I'm jawing with the "locals" with 110 vac. I will drop the drive from the rig and try to keep output around 500-600 watts, but wanted to see what she'd do. My meter is not very accurate on the MFJ-989C, but I just ordered a Palstar AT2K today to remedy that and my troubles getting accurate tunes with the MFJ. After that, I'm pondering a heavy duty dummy load. My wife may divorce me if I spend any more money!
Sweet setup sir! Very nice radio and the amp is the icing on the cake.
Also, I've had quite a bit of on air help getting the audio right. I currently run the W2IHY 8 band eq and EQ Plus
I have heard their can is weak and to replace it with a Sherwin Williams one. Are the rumors unfounded?I just use the big oil can dummy load from MFJ. It's inexpensive and works great.
Julius rocks. Best customer service EVER. I just use the switches on the back to switch rigs. A little cumbersome, but it works.I run that audio stack also I also use the iPlus for switching between rigs while using the same mic/speakers. It works great.
Seems like a legitimate question to me, since bad seams would get oil everywhere.
