Belated up-date, sort of.
Got the thing mounted, 'firmly', now. Amounted to a lock washer, basically, and really cranking it down tight. Did 'deform' the tool box's lid some, not nearly as much as I thought it would. Still thinking about a different way of doing it, a get around to it sort of thingy.
Also found that the tool box wasn't as 'fixed' as I thought it was. As in that antenna added enough 'torquing' force to straighten out a 'J' bolt that held one side! Looks like I'm going to invest in a few bolts and drill holes in the bed rail/box. Oh well, that ought'a take care of any 'grounding' issues, maybe. Also found that opening that lid takes both hands and a grunt or two. Don't have to slam it shut anymore, just don't get you fingers caught! You won't loose them, they'll be safely inside that tool box.
Also found some very nice doo-hickies call 'Anderson Power Poles'! Yeah, I know they've been around for a while but for whatever reason I just never used them before. Oh, they are nice! And a terminal block for them, eight connections (+ and -), so with one input line, seven outlets. The thing's rated for 45 amps at 50 something volts so ought'a handle anything I might need power for. In the process of running the power line. That ought'a get rid of that cig.lighter mess for several different power taps, not even counting the radios.
For me, this is progress! Even the backward steps, sort of. The boss at work has gotten sort of used to seeing that 'thing' on my truck (head shaking stage), so now is probably the time to put the long whip on it. May make a 'brand' flag to put on it, that ought'a relieve some of his 'stress', advertising. You think?
Oooo... Ooooo! Brilliant idea! Two flags, the competitions brand on mylar, 'our' brand on something else. Hit the mic button, the mylar goes up in flames, poof! Dang! I'm gonna get a raise!
