NEW RM Italy BLA 703 Base Amplifier
Eric, thank you so very much for your answer!! Very much appreciated. Also having no FB account, I would love for you to paste your infos here as I had a very hard time reading your posts. Sorry for the hassle. Despite my problems opening your pictures I read all your threads and was very impressed by your extensive knowledge and expertise.
Happy New Year :)
Giles
The "copy & pasted" info (below) is the majority what's on the FB link which was placed several times earlier in this "Thread", and is being repeated here for those who don't have a FB account for the ability to view it...
Title:
Conversion of the BLA-703 to operate for both the 10 and 11-meter bands, and also how to change / modify the "out-of-band" safety shut-down parameter (the 4-beep warning explained on page #9 of the user-manual) to what has been nicknamed as the "American-mode", for radios with less than "stellar" harmonic suppression (ie: "cranked & spanked" rigs)
See the first (1st) attached photo of the rear, of the front-panel CPU board (central-processor-unit).
Near the bottom right of the board, you'll see where there was a VERY small "surface-mount" resistor (circled in red) of which is now removed.
Your own unit may have either the afore mentioned SMD "chip-resistor" (labeled as "000" ohm) or there may be just a small "solder-bridge" across the solder-pads.
When the 000 ohm resistor (or solder-bridge) is there, the BLA-703 will ONLY operate for the 10-meter band (as shown on page #8 of the user-manual).
Once it (the resistor or jumper) has been removed, it will now operate for both the 10 and 11-meter bands.
BUT., do NOT attempt to use the amplifier for the 12-meter band (ie: 25 Mhz), or you could cause damage to the 16 MOSFETs (and other components) contained therein.!! This is because as frequency decreases (towards the 12-meter band) the "gain" of the amplifier increases greatly, and can be seen at the bottom of page #8 in the owner's manual, in the chart named "BLA-703 gain versus frequency".
*I hope I don't have to remind anyone, that the amplifier MUST be un-plugged from the AC outlet BEFORE the above modification is done.!! ;)
Now., this next SUPER easy modification (of the internal "firmware") is for those folks that may have radios that are not as "RF-clean" (of transmitted harmonics) as they should be., caused by either your radio being "cranked & spanked" (as I call it), or the output LPF (low-pass-filter) circuit not being as well designed as the manufacturer should have made it.
In these cases (ie: not so perfect transmitters)., you may find that one of the six (6) internal, self-protection modes (the "4-beep" out-of-band warning mentioned on page #9 of the owner's manual) may "trip" your amplifier back into standby-mode (which can be easily "reset" by simply switching the standby / operate button between, on / off / on).
This 4-beep, out-of-band warning, shut-down condition (when using a "harmonically-rich" transmitter) will occur more often when modulating with either a steady tone, or an "auuuuuudio", or a whistle.
If this occurs a bit too often (or even when just talking "normal".?)., there is a "firmware" change which can be very easily made by the operator / user, right from the front-panel itself.! (y)
When the Firmware is in the factory default mode, you'll know this each time the amplifier is powered-up., and is indicated by hearing one (1) long "beep" each time the unit is powered-on.
To change the internal Firmware to be less sensitive to the out-of-band (harmonic sensing), 4-beep protection-mode (which is caused by the amplifier sensing 2nd and 3rd harmonics being generated by your transmitter)., you just start off with the main power-switch off.
Then., while holding in the SSB button (nice and solid), simply flip the power rocker-switch back on, while still holding the SSB button until it's finished "booting-up".
After that's been done., each time the amplifier is powered on., instead of hearing the one (1) long beep., you'll instead hear it produce the "Morse-code" signal for the letters A and M (ie: dit-dah., dah-dah) for what's been nicknamed the "American Mode" (because most American radios have been "peaked & tweaked" by either the "dealer" or some self-proclaimed, wanna-be "tech"), or that the manufacturer of the radio did not design the transmitter's LPF (low-pass-filter) to be as good in its rejection of harmonics as a standard, FCC-approved Ham / Amateur rig.
BTW / FYI: Even some actual / true, Ham / Amateur rigs may still produce just enough harmonic-energy to "trip" the amplifier's VERY sensitive detection circuity "threshold", and may still need this Firmware change to be made...
BUT., even with the "American-Mode" firmware activated, if your transmitter is "cranked & spanked"., and you "hold" a tone, a whistle, or an "auuuuuudio" for more than about 1.5 seconds, it will still "trip" the out-of-band (ie: harmonic) sensing circuit.
Folks NEED to remember., that this is NOT just some "wanna-be" Ham / Amateur, linear amplifier, like virtually all other transistor / sold-state amplifiers EVER made on the market. This amplifier is an actual "FCC certified" amplifier, which has gone through 10s of thousands of $$$$$ of testing and approvals to "the powers that be", and on top of that, it was painstakingly designed and engineered to be as "bullet-proof" (electronically) as possible., within reason of course.! ;-)
This amplifier was designed "from the ground & up" to be operated with true and "clean-output" Ham / Amateur transceivers, but of course will work just GREAT with CB and Export radios, that have at least a somewhat harmonically-clean output.! (y)
I mean., how many other "true" linear amplifiers (whether FCC certified or not) have as many as six (6) different, built-in, self-protection modes.?!?
Again., see the bottom-left corner of page #9 of the owner's manual for all the six (6) self-protection modes, and then find me a comparable amplifier., output power, dual power-supplies, build-quality (9+ pound aluminum heat-sink and 2mm thick steel housing, totaling 30 pounds.!)., with which you'd virtually have to "work at" (because of all the internal protection modes) doing your best to "blow-it-up".!
*I hope the above mini-novel was both understandable AND informative for most Folks that have actually taken the time to read this point (and to those I say THANKS.!)., as I do NOT "make a Dime" doing all this research, taking photos, labeling them, my 2-fingered typing, proof-reading, editing, (each step several times over)., and spending $$ having phone conversations to Italy, to make as sure as possible, to get my information straight.!!
I also do it because I'm quite passionate about helping others to get a better "grasp" concerning all this Radio & Electronics "stuff"., to help those who actually want to know the Truth., and for those who are humble enough to un-learn decades of "urban-legends" (y)
Regards / 73
Eric Klein
Klein Communications
Also as KY8E
Howdy Gile, unfortunately, the short answer is no :-(
This is because the "1st-run" of them (ie: low serial-numbers) were only sold in Europe (no direct sales in America until Nov. 1, 2024) and of course being European sold, were "Export" units (ie: 11-meter band "open").
BUT., some of those "1st-run units" had a problem with damage occurring during the final shipping "leg" from the distributor to end-user (ie: caused by typical "throwing about" in transit) in which the amplifier's internal VERY heavy (9#) heat-sink, partially breaking-away from the rear of the steel outer cabinet :(
So., most of those units were shipped back to RM to have the heat-sink mounting system to be GREATLY improved :) and then shipped back to the distributor(s).
And while back at the factory, most all of those units, also had the new Firmware "flashed" into the front-panel CPU board.
Bottom line.??
You'll only know for sure, when you attempt the front-panel accessible, change-over (and back) as described in my article.
Regards,
Eric
PS: Here's the web-link to that article:
If you don't have access FB, let me know, and I'll just copy & paste the section of that article which explains the simple process in excruciating detail ;)
Hi Eric, after writing to RM Italy myself, providing them with the serial number of my newly purchased BLA-703 amplifier, see below the answer I got from the factory and those are good news!
« It was tested in November 2024 and should have firmware 1.4 which is the latest, that features the reduced sensitivity to spurious signals in TX » — RM Italy
I'm very glad to hear that.! :)
As I had mentioned before, the 2nd production-run which was finished in October of 2024 had the new Firmware.
Just as an FYI., the way to read the 6 digit serial-number of an RM unit is as follows:
Example given ( 400224 )
The last 2 digits represents the year (24 = 2024)
The middle 2-digits represents the month (02 - February)
The first 2-digits represents the the assembly-line number (40 = the 40th unit made in that month)
Hope that helps others who may read this.!
Regards / 73
Eric Klein
Concerning the FCC certification of the BLA-703 linear amplifier.
After what seems to be like an eternity (since early 2024.!) of dealing with FCC administration issues, the RM of Italy company just received today (1-16-25) the actual "hard-copy" of the FCC certificate for the BLA-703 base-station, linear amplifier.! (y) :)
There were MANY months of "administration problems" on the FCC website which had proved to be VERY difficult to resolve, and was almost unbelievable as to how much time AND money the RM of Italy company had wasted on overcoming the bureaucratic "red-tape".!
The required independent "test-house" had successfully completed ALL the tests required by the FCC, along with the COMPLETE report findings., but they were unable to "up-load" the documents onto the FCC website because of "issues" in our wonderfully efficient (NOT.!) government agency.! :(
So., "drum-roll please".....
Attached is a copy of the LONG overdue FCC certificate which was sent to me this morning by the company's owner and lead engineer.! (y) :)
Regards / 73
Eric Klein
Also as KY8E
