cat driver,
dont let 'em confuse ya.
they are all correct in their comments about the antenna, but i think they are getting a bit off point of your original intention.
i currently own and run this antenna as my main CB/11m antenna.
its called the "top one".
this is the antenna you want for your application.
it will outperform the A99 on the same 20' mast.
i also own an antron, and this antenna is definitely quieter on receive, and i dont mean it has less "ears".
it takes a bit of time to put together, but it is not any more difficult than any other alum. cb antenna.
the hardware is kinda cheap. you might want to upgrade to stainless steel bolts and nylon insert nuts.
really helps keep things tight in the wind.
here are the main things to remember about this antenna:
1. you must support the hoop against the mast by using UV resistant rope, or cable ties at four points.
2. you must have a good metal to metal connection from the top mounting bracket of the antenna to the mast, and from one mast section to the other. might have to scrape some paint.
3. the mast must run down past the hoop for 8 feet minimum.
the antenna is just over 7 feet without the top element, so this will be fine with your setup.
4. the coax must run down the mast all the way down past the hoop for at least 8 feet.
best to keep it secured to the mast all the way to the bottom.
thats it. mine works VERY well. i have it on a 50' pole, but i have operated it 10' off the ground with great results too.
one tip: when screwing the various elements to the mounting bracket, the rubber insulators can make threading them in quite difficult.
coating the threaded end of the element with some automotive tune up grease will greatly ease the installation and assure a tight fit while maintaining conductivity.
dont use too much, just a light coating.
follow these instructions, and you will have a very low SWR with no fuss.
best of luck,
loosecannon
