Check it out - TenTec has released extensive information on their new mid-proced Eagle Transceiver:
With tuner, it is priced at $1995 and will be shipping as soon as it has FCC approval. The receiver specs look very good, as you would expect from a TenTec. I've copied and summarized the specs:
General Specs
-Microphone Connector: 8-Pin
-Headphone Jack: 1/4" Mono
-External CW Key Jack: 1/8 " Stereo
-External Speaker Jack: 1/8" Mono
-Aux DC Output Connector: RCA x2
-Frequency Range TX: Ham Bands Only (160-6M)
-ACC Din Connector: 8 PIN DIN Connector - Line In, Line Out, Aux PTT, Ext -Key, Clock/Data/Enable, Ground
-DC Power Connector: Power Pole
-Fuse: Automotive Blade Style Fuse, 25 Amp 32V
-Frequency Range RX: 100 kHz - 30 MHz and 48 - 54MHz. Specifications apply within Amateur Radio bands only.
-Tuning Step Size: 1, 10, 100, 1000, 10000
-Frequency Stability: Maximum +/- 0.5 PPM over operating temperature
-Antenna Impedance: 50 ohms nominal.
-Antenna Connectors: 1 x SO-239 transceive
-Modes: USB, LSB, CW, AM (optional), FM (optional)
-Memories: 100
-Frequency Accuracy: +-5Hz @25C, 1 Hz tuning resolution
-Supply Voltage Range: 13.8V +/-15%
-Operating Temp. Range: 0-50 degrees Celsius
-Dimensions (HxWxD): 2.9" x 8.5" x 10.25" (excluding knobs and connectors)
-Weight: 7.25 lbs with all options
-Construction: Molded plastic front panel, aluminum chassis and texture painted steel covers
-PC Control Port: USB (using FTDI USB to UART Driver)
-Display: Custom FSTN monochrome LCD
-Display Backlight: 256 colors X 16 intensity levels
Receiver Specs
-SSB Sensitivity: 0.5uV, 2.4khz, 10dB SINAD, preamp off
-AM Sensitivity: 1.3uV, 30% Mod, 6kHz BW, 10dB SINAD, preamp off
-FM Sensitivity: 2.2uV, 5kHz Dev, 16kHz BW, 10dB SINAD, preamp off
-Selectivity IF1: 2.4khz standard, 9.0015 MHz, 2 options
-Selectivity IF2: 30 KHz Lowpass filter
-Selectivity, DSP IF: 127 built-in DSP filters from 100-15000 Hz BW.
-IP3 (Third Order Intercept Point): 21.5dBm/20kHz tone separation, 19.5dBm/2kHz, preamp off
-IMD3 Dynamic Range: 100dB/20kHz, 99dB/2kHz, 300Hz BW, preamp off
-Blocking Dynamic Range: 141dB/20kHz, 130dB/2kHz, 500 Hz BW, preamp off
-LO Phase Noise: -132dBc/Hz@20kHz, -121dBc/Hz@2kHz
-Noise Floor: -137dBm/300Hz BW, preamp on
-Image Rejection: 1st IF:>90dB/HF bands,>70dB/6M, 2nd IF:>73dB
-IF Frequencies: 1st:9.0015 MHz, 2nd:22.5 kHz, 3rd:0Hz (DSP)
-IF Rejection:>70dB
Other Spurious Response Rejection
-Rejection:>80dB; Birdies: <-100dBm equivalent*
-Pass Band Tuning: +/- 2.1kHz, 5Hz steps, 80 step deadband middle of POT
-Attenuator: 10 db
-PreAmp: 12 db
-Audio Output: 2W into 4 ohms, <3% THD
-RIT range: +/- 8.2 kHz
-RIT Step size: 10Hz
-S-Meter Reference: S9 = 50 uV RMS
-TX>RX Recovery Time: < 20 ms
-RX Headphone Output: Designed for 16-32 ohms impedance headphones. Usable at 8 ohms
-AUX Audio Output: 500 mv
-Auto Notch: IF DSP, multi-tone
-RX Noise Reduction: IF DSP, adjustable
-Noise Blanker: Optional HW, 2 levels of blanking
-RX Current Drain: 1.25 Amps
-# of IF DSP Filters: 127 built-in DSP filters from 100-15000 Hz BW.
-General Coverage Receive: degraded specs outside ham bands
Transmitter Specs
-RF Power Output: Adjustable, 5-100 W, +/- 1 dB
-CW & SSB Duty Cycle: continuous service @ 100W
-AM,FM,AFSK,PSK Duty Cycle: continuous service @100W, 50% duty cycle (Tx/Rx)
-AM TX Bandwidth: 6k
-Microphone Input Impedance:>10 k-ohms at 1 kHz
-Microphone Sensitivity: 1 mV RMS for full power output, internal gain adjustment, 9v dc power for electret elements
-FM Deviation: +/- 5 kHz peak nominal
-AUX Level Input: variable, 200mV nominal
-SSB Carrier Supression:> 70 dB
-Unwanted Sideband Suppression:> 60 dB at 1 kHz
-Harmonic & Spurious Outputs: <-50dBc @100 W <30MHz; -60dB>30MHz; -43 dB <5 W
-T/R Switching: PTT or VOX on SSB, AM, FM, QSK on CW
-CW Keyer Type: Internal Curtis Mode B
-CW Rise and Fall Times: 5ms
-CW Offset: adjustable
-CW Keyer Speed: 5-50 WPM, adjustable weighting
-Current Drain: transmit 20 amps typ.
-Third Order Intermod: Better than 25dB below peak
-SSB Generation: DSP Generated
-# of DSP generated TX bandwidths: 3 built-in DSP filters - automatically selected - standard = 2.4Khz for SSB/CW; optional = 6Khz for AM, 12Khz for FM
Antenna Tuner
-Type: Reversible L-network
-Matching frequency range: 160 to 10 Meters, no Six Meters
-Matching impedance range: 10:1 SWR typical
Options
-Filters: 2.4K standard, optional = 300, 600, 1k, 1.8k, 6k, 15k
-Noise Blanker: daughter board module
-Roofing Filters: 4-pole xtal, 9.0015 MHz center frequency
General Specs
-Memories: 100
Receiver Specs
-IF Rejection:>70dB
-Attenuator: 10 db
-PreAmp: 12 db
Transmitter Specs
Antenna Tuner
Options
