These antennas ever demonstrated in the real world that can overcome a 5/8
Several people here have tried to tell you that they have built them.
Read this Quote slowly and very carefully and try to understand, it has nothing to do with Antenna modeling and relates to direct experience with comparing the 1/2 wave, a 5/8 wave and the vector.
Please think a little bit before you dismiss Homers testing.
Posted by Homer, a man who has built many antennas and reported his testing here.
If my V4k antenna works better at 37' tip height than my 1/2 wave or 5/8 wave (which it does), then I attribute this to the antenna design, not height over objects or raised current maximum due to length. This is also a piece of your argument that is not being factored into the discussion you present.
You ask
You ask for experience, but when it is presented to you, you simply post something using a program that will still see the antenna as a J-pole.
Several times I have told myself I will not respond to your posting again, but I can not help it. I can not understand why you are so determined to keep posting pictures made with software that still fails to model the antenna properly.
I am sorry it hurts your pride that your beloved modeling program is wrong, and a new, more advanced modeling program has come along and proved it wrong.
I hate to be rude and blunt but lets see if you understand if I word it this way:
NEC IS ******* WRONG IN THE WAY IT PRESENTS THE ANTENNA UP TO THIS POINT.
There is no better proof than this:
MANY BROADCAST STATIONS HAVE TAKEN DOWN THERE EXISTING ANTENNAS AND REPORTED BETTER COVERAGE WITH THIS STYLE OF ANTENNA, EVEN AFTER REDUCING THE NUMBER OF ANTENNAS USED.
How hard is it to understand the above words?
If all these guys that rely on the antenna working properly agree that they work better, how do you explain the real world experience that have reported?
They are station engineers for gods sake, not the guy selling the antenna, not the guy installing the antenna, but the guy whos ass is in the line if the station coverage does not improve after the switch.
Any more Plots and cartoons that you Post from this point on will be disregarded as garbage because about everyone here already knows that it will not model the antenna correctly.
Until you build and test the antenna for your self, your words here....will be meaningless and not worth any more replies.
It is not hard, I have seen them built with very little cost in materials.
