New Victim! (project) Realistic Navaho TRC-457
Do you have any idea what would cause this.
Yep. Turning up the AM modulation limiter. This radio has a modulation transformer for AM transmit, just like a Cobra 29. It feeds peak voltages into the final that stay below the capacitor's 25-Volt rating. Turning it up now causes voltages that exceed the rating to reach this part, and it breaks down from overvoltage.
It should be replaced with a 50-Volt part (better) or at least a 35-Volt rated cap. Installing a 25-Volt cap will produce a repeat performance.
I struggle to explain things. You do a fantastic job. Thanks. :)
Just takes practice. Way too many of these little explanations are distilled down from an explanation repeated to a hundred customers, each with the same repair. That kind of repetition eventually gets the story shrunk down to the essentials.
