Bundled up and went out today to bury some radials. I had bought a spool of some surplus wire at a local Restore. The spool had enough 14 ga insulated wire to bury 8 radials. Lengths were anywhere from 18-25ish feet. I was able to bury each of them pretty easily. The sod was pretty soft so cutting some slits and pushing the wire into the ground was easy. I used some lawn staples to keep them in place and cut the slits and pushed the wire into the ground. Lots of mud on my shoes and pant legs. Ground here is a clay soil so it was easy to mold the soil back over the wire. When done I was hard pressed to see where the radials had been laid. Going back to Restore and buy the other two spools to finish the radial field. Total cost of radial field will be $12ish dollars. Love good deals.
Being retired is a blast. Extra time to have some fun. Spent my working life working hard in a lumber mill out in Scotia Ca. After leaving the mill I worked in a fab producing memory chips for computers and cameras. This job was at Micron in Boise Idaho Also made imager chips for cameras and phones. After that job worked as a satellite installer. That was a fun gig. Now I stay at home and do honey do chores and fun projects of my own.
