I don't understand all this ham nonsense. I just wanna talk on the radio.
Sent from my SCH-I545 using Tapatalk
Amateur Radio involves Science, Algebra, Calculus, Trigonometry, Geography, the use of languages including English, some knowledge is required about the construction of efficient antenna's, phase relationships, VSWR, how a transmitter works, harmonic's, more complex things like how to do a field evaluation - survey of your signal when you use more then the minimum amount of power allowed - most bands it is 100 watts.
The rules - since you would have anarchy without the rules.
Since you are dealing with lethal amounts of power, you need at least a basic understanding of grounds, how feed lines works, and even the most basic precepts like which wire is ground and which wire is hot - even if it is only 13.7 DC..
A local ham died, his equipment was still in his room. His family found his equipment, one radio looked a lot like a scanner, it was a Two Meter Mobile.
They did not understand voltage and they wanted to try it out, so they connected it's power leads to an extension cord and plugged it into the 120 VAC. It made a pop noise and that was the end of the radio.
A friend of mine needed a donor radio because his display went dead.
The display in the donor radio still worked.
Had the owner not plugged it into the wall socket, it would have been worth several hundred dollars, after their mistake, they were glad to get $40 for it!
I loved CB radio when I was a kid, there wasn't a lot to learn.
Put up a antenna, cut it for resonance, hook up some power and talk.
I wish that when I got my license I would have been able to find one real ham that I could have used as an Elmer that could have told me which radios to buy, for what I wanted to use them for.
Had I had an Elmer, I wouldn't have bought a Yaesu FT 8900R, I would have bought something that would do Single Side Band, then I could have enjoyed some of what the other forum members spoke about - playing side band, which would be a lot more enjoyable then playing CB on the FM with the repeaters.
Other then the occasional rag chew on FM, and the weekly nets, there isn't a lot that you can do with a FM radio anymore ..
Nobody here does packet, not that there is a lot of need for it.
I don't believe that APRS was invented so people could track their vehicles.
There isn't anyone here to show me how to work Satellites.
I actually feel cheated when I hang out with nice people like you, even though we aren't on the radio.
