Retevis is giving away Radios for the New Year and Every Member is Eligible. Click Here to see the details!
Bad solder joint. I was getting 13V at C172 and at a couple of places beyond that then it just stopped. Close examination of the board and I found a bad solder point. Crazy!
Now back to my original and much larger problem. Have no TX power and I just burned up L39- again. Stuck because I have no idea where to get a replacement for it as I pilfered that one from an old radio. And of course even if I did have one, clearly something is causing it to burn up which I assume is also the reason there is no TX power and I would likely just burn up another one.
Need help lost my channel chart . Cobra 148 GTL with a 8719 and 11,1125 crystal 26.175 to 28.045 , Need the chart I can fill in the blanks slide 2ck up and 12 kc down
