I found this:Yes, he tested his jumpers and they were fine, he used new ones anyway, same result.
C199 maybe?
I think there is mention of the galaxy 44v aquirring an oscillation on transmit audio which turns out to be C199.
It's on the archived version of cbtricks under galaxy symptoms and cures.
Not really a hum. Almost a 1khz constant tone but lower in frequency tone, like say 600hz to 800hz.
SWR between radio and the amp is 1.3, SWR from antenna is 1.3.
This issue may be the reason someone recapped it and tried to align it (which screwed up the alignment) and then sold it.
and although I don't have a saturn schematic on hand that is clear enough to read, the DX45 schematic shows where this cap is. Looks like the mod simply replaces the jumper with a ceramic cap (in this radio, C193) that bridges the chassis to circuit ground
