NOS !! R.F. Limited VC7700 Voice Pitch Controller in Box, Instructions
Wire Weasel
Senior Moment
Dec 13, 2008
3,196
862
223
Very rare find. New Old Stock RF Limited VC 7700 Voice Pitch Controller in Box with Instructions and factory Earbud for monitoring.
Hooked up to test. Works perfectly as should. Absolutely new and spotless. 8 stages pitch control high & low. Makes a man sound like a woman, woman sound like a man, adult sound like a child. Setting 3-High makes you sound like you're talking with helium …. this thing is nuts !!! If you're using an echo mic or mic with any on-board noise toys like a Tweety Bird, it changes the pitch-tone of the noise toy also or anything else you input into it. Factory earbud for accurate monitoring of how you sound. Adjustments on rear for Monitor Level and Mic Gain …. so it has an on-board audio amplifier which will turn a hand stock mic into a power mic as well. - 4 Pin modern Cobra/Galaxy plugin both ways.
Had to make a minor repair. When received the plastic in-line fuse holder was broken. Replace with new and longer fused red/black power cord wired from the inside. Cord now is 3-4 feet long. Came with a short cord.
Also note then when I first tested I connected to same power supply that radio was running on. The audio squealed no matter what I did. So I moved it over to a separate power supply and all was 100% good. Every installation is different so just know that you may possibly have to run this box on a separate power source than your radio (base stations). Mobile operation shouldn't be a problem seeing as you're on battery.
These and their other sister models are hard to find and regularly sell for $300 on ebay and that's where this one will go in a few weeks if I don't sell or trade otherwise before then. ….. and this one being NOS with everything is even more rare and1.77.jpg unheard of.
Will sell for $250 shipped Priority, Paypal Gift or money order …. also will consider trades for something of $250 value. No tube boxes please …. whatcha got ??
Also can be used as a Tone Control for your audio. If you radio's audio circuit sounds tinny or your mic is tinny sounding, you can run Setting 1 or 2 LOW (down) and it will add a nice baseyness to your audio.
