Anyone know what the mod is called and what it consists of? Of course it'll differ from radio to radio. I just wanted to do a little reading on it to have something to play with. Any help would be greatly appreciated. Thanks!
Well, most (all?) of the MMM setups that are on CB ch 28, also transmit on 28.380 @ the same time.
YMMV
What you're talking about is probably what we used to call the "Nuke Duke".
One guy in eastern KY nicknamed it "World of Sound".
I like to call it the "Clone Army", since that's what it looks like on the spectrum or waterfall display of a SDR.
Dozens of exact clones of your on-channel AM signal, a dozen or more channels above and below it.
20 years ago when someone asked "What are we gonna do to keep this old radio stuff on the air when you retire?" I said I would publish the plans for this trick. That would be the end of CB, and give them something to remember me by.
Still have no plans to retire. Just can't understand why nobody else has figured out how to do this. I submitted a talk proposal to show how it works at a couple of hacker cons, but it was never selected for either con's schedule.
Called that one "Analog Spread Spectrum". And yes, that's what the acronym spells.
Back in the 90s there was some interest in finding a way to interrupt your car's FM radio when an emergency vehicle's siren would not be heard over your car's stereo and air conditioner. Never had any patent for this, only worked as a developer for the folks who did have patents. It never went anywhere. Getting paid for design work is the hardest part, so I walked away.
Thought about selling the pc board ready to install in a CB, but it could attract the kind of attention I usually avoid. Should build a couple hundred and just find some third party to market them. Keep my name out of it.
But here's the basic technique. Generate a square wave with an accurate frequency of 10 kHz and an amplitude of 5 Volts or less peak-to-peak. A potentiometer sets the actual drive level into a 56k resistor. The other end of the resistor goes to the cathode of the PLL's vco varactor diode.
Easiest way to generate an accurate 10 kHz is to take a cheap 10.24 MHz crystal, and divide that frequency by two, ten times in a row. That's how a 40-channel radio's PLL chip does this on the inside.
It's frequency modulation, pure and simple. FM produces sidebands like AM, but they behave differently. Each FM sideband, 10 kHz apart is a fairly-exact copy of your original single-channel AM signal.
Thermodynamics still apply. Spread your 4 Watts across 40 channels, and that's 1/10th of a Watt per channel. Won't shut down much of anybody else.
Works okay on a Cobra 29, or a RCI-made channel-selector radio. Never tried it on any kind of "Ranger" ham-type radio, only the ones with a 40-channel selector.
Radios that have the VCO built into a flat-plate module are less effective. Works best when you can feed directly to the cathode terminal of the VCO's varactor diode.
Need to post it on a YT vid.
Just what the band needs. :-(
Why? What are any valid reasons to do this?Anyone know what the mod is called and what it consists of? Of course it'll differ from radio to radio. I just wanted to do a little reading on it to have something to play with. Any help would be greatly appreciated. Thanks!
