NVIS, Near Vertical Incidence Skywave
Nursecosmo,
This isn't a criticism, just curiosity. Why would you want a NVIS antenna on a mobile?
As part of an emergency com group, we use VHF for A and B entry teams into disaster zones. The B teams are used as VHF simplex or mobile repeater relays back to the "C" HQ location. VHF is used for the entry teams because vertical HF antennas often have a pretty extensive skip zone. Skip zone - Wikipedia, the free encyclopedia If HF NVIS were to be used by the A team, then there would be no need for the relay teams. The C location will never be more than 200Km out, so NVIS would be an attractive option in many situations.
Plus one of those tied down whips would look really cool on my jeep.:D
Nursecosmo,
Okay, I think I see where you are going with that NVIS thingy. Have you considered that by correctly picking the HF band you can pretty well do away with any "skip zone" problems? It's a quite common way of doing things.
Nursecosmo,
Positive reliability is what we are after. If it were as easy to make contact between 50Km and 300Km as you claim, simply by using the appropriate frequency, the military would not have to use NVIS for Battle field over-the-horizon communication. Remember that, that mobile rig only has a 3 meter high antenna at most, so OTH communication is much more difficult with a vertical antenna. Not to mention the difficulties of communicating from one valley to the next in mountainous, or even hilly areas. As you mentioned above, proper frequency selection is still required, but is much more effective for regional communication, when a high take-off angle is used.
I'm know that reliable communication is possible with verticals in most situations with a little fiddling, but I want good communication in all situations with as little tweaking as possible. Thanks for the suggestions.
here ya go: a mobile NVIS antenner ;)Loop Antenna - Mobile / Transportable NVIS Series
the other cool thing about NVIS while mobile is that if you're really doing NVIS, it's darn near impossible to DF the transmitting station. That's the other reason that the military uses it.
    Greg T has left the room.
