  • The Retevis Holidays giveaway winner has been selected! Check Here to see who won!
Ofcd vs fan dipole. Opinions?
nfsus
Yeah its turned off, touch it
May 9, 2011
507
271
Arkansas
I’ve been running a 80-10 off center fed dipole with the feed point at 45’ for a few years. I’ve been thinking of switching to a fan dipole. The ocfd is fine just wondering if a fan would be better. Any opinions on a difference between the two? Is one better than the other?
fan dipole installed correctly works pretty good.
solar cycle is running strong now so about anything that will lump a signal out will work.
With a fan you can tailor where the antenna is resonant at for what portion of the band you want to work.
OCF you sort of use what you have a touch up with tuner.
OCF is easier to build and install.
Fan is of course multiband direct fed no tuner required,,sort of.
PIA to tune.
transmits lobes same as a typical dipole if installed at least 1/2 wl agl.
Build one and have fun.
  • @ Galanary:
  • @ kopcicle:
  • @ unit_399:
