Old D-104 Base Mic help
I have had luck hitting the wax with hot air, assuming the rock is still attached to the back wall. When the foil gets bent, distorted, it puts an odd or uneven tension on the rock ?yoke? inside and reheating the wax can reset its hold between the diaphragm and shaft. Sorry, I can't recall the correct terminology for these parts.
No problem with the terminology. You got the point across. Thanks.
