Thanks, I appreciate the infoView attachment 47420
Texas Star (Outcom) If you trace the connection from the + side of C4 to the switch, the + side of C4 goes to the 2nd pin on the front left of the SSB switch, if you solder or jumper the 2nd to the 3rd pins on the front left of the switch, SSB Delay will be always on. There is no need to remove C4 and move it to across D1. This does the exact same thing. I have done this to a lot of TS amps, 250, 350, 500 and 667's.
Thanks for the informationYep, it will work the same for the DX500 as well.
~Cheers~
Thanks Hd ! Just thought I would ask before attempting the mod . I'm guessing this amp is on the older side ? (but in very good condition) I can recall over the years Texas Star maybe fixing that problem by putting a rocker switch in the back ? I never really cared much for those push button lighted power controls on these amps but it seems it's always been the Texas Star way. I'll do some pic's once I get to it. Much thanks. SwitchI do believe you have it all correct, yes.
I made a mistake , I had the wires on the wrong side of the switch , moved them directly across and all is working great ! All power modes in SSB with good relay delay , No delay on AM after turning off the toggle switch as it should be . Thanks to all that had anything to do with this thread over the years . She's ah work'in ! SwitchWell the switch thing seemed to work the relays better on High power on SSB (much better then it was but far from perfect) but in my case the switch still needs to be on for AM as well ? because with it off it shuts down the radios receive but there is no delay on AM after unkeying so that doesn't become a problem ........unless I did something wrong ? Could have just jumped the pins and left it at that for the fact there is no delay on AM anyway . Go figure ? Much thanks . Switch View attachment 59794
Yours is not as old as my DX-250 as far as I know. It has non Toshiba older transistors in it. Probably right after they stopped labeling them Outcom I would think.Thanks Hd ! Just thought I would ask before attempting the mod . I'm guessing this amp is on the older side ? (but in very good condition) I can recall over the years Texas Star maybe fixing that problem by putting a rocker switch in the back ? I never really cared much for those push button lighted power controls on these amps but it seems it's always been the Texas Star way. I'll do some pic's once I get to it. Much thanks. Switch
