Omegaforce S45HP???
Used some tough epoxy to mount four pieces of nylon that were drilled for the screws.
Two screws/inserts for each fan was enough.
The heat sink stays stone cold this way . . .
These fans were made to use with ~12v; not 13.8v. So, if there is too much voltage to them they won't run very well. Each one will run at a slightly different speed anyway and the imbalance is magnified with the additional voltage/fan speed. I might try a couple of three diodes in series and see if I can get the speed/voltage to where it should be.
Its the noise factor that I am dealing with now. Those DC brushless motors still throw off noise that is being picked up by the audio circuit. Perhaps a 472 disc cap across the +/- leads and three diodes in series on the positive lead is my next move.
voltage regulator
Amazon sells 1 amp. Adjustable power supply kits but the diode deal is quick and simple. :pop:
Was on a local SSB net tonight, I was told my audio was a tad bit raspy. I listened on my TS-590 and agreed. I held the mic back a few more inches and it seemed to clear up a little.
I am used to close talking, but I don't think the stock power mic likes that much intimacy. I get good AM reports though. It almost sounds like a little RF, but need to play around a little more.
I never run mine over 12 o'clock on the mic gain. I am actually not sure how loud the factory power mic is on setting... never opened it to see. These rigs have a lot of modulation with the factory mic.
73,
RT307
How would you keep your modulation on ssb at the optimum level without overmodulating?:huh:
This might be going over to your DX959 thread, but it applies to any SSB rig, so..... You might be surprised how little of a difference folks will see in your signal by "only" average speech at around 70% vs. peaking at 100%. Unless you have a good local that will give you an honest report on how you sound, you'll probably need to look at your transmission on a scope. I'm pretty sure you sent your rig to DTB, and he should have all the tech stuff for testing, so they could probably make a good recommendation for you once your radio is finished being tuned.
It's really not about squeezing every last watt out of the rig... it's about getting a good clean signal and audio out of it. The latter is what m42duster is trying to do with his. :)
73,
RT307
