I've been having a time trying to get my Connex CX33HPC-1 dialed in on my newly purchased oscilloscope. I don't have a proper signal generator, so I've been using a signal generator app on my smartphone at 1000hz, and sometimes a whistle or "auddiiioooo" into the microphone, and adjusting the trigger control to stabilize the pattern. I've been pulling an RF sample using the oscilloscope probe laying next to the RF output of the radio, but not hooked directly to it. Just kinda dropped down in there next to the little wire that feeds the SO239.
If I adjust the modulation control for symmetry on the scope without pinching off the carrier, it absolutely KILLS the PEP off. If I barely, just slightly pinch off the carrier (still not flat topping the peaks), I can get more PEP, right around 40-45 watts. Listening to myself on another radio, I can tell an increase in modulation, but am not hearing any distortion. It gets louder but isn't fuzzed up. In a situation like this, is it okay to pinch off the carrier a just little bit? I know it isn't perfect, but it's about as close as I can get it without sacrificing my audio.
Is what I'm seeing on the scope accurate? Obviously I can vary how much the waveform is pinched by simply changing how far I'm holding the microphone from the audio source. A 1000hz tone from my smartphone is pretty dang loud, compared to a normal speaking human voice.. I AM seeing "one box up and one box down" of carrier on the scope with a normal carrier.
Right now, I have the radio tuned at the following just because I plan to drive a Carl Built 200HD (2x2879) with it:
L Power - 2W carrier, 35W PEP (very pinched off carrier, not flat topped)
M Power - 4W carrier, 40W PEP (slightly pinched off carrier, not flat topped)
H Power - 10W carrier - 50W PEP (no pinched off carrier, not flat topped)
Sadly, I cannot run the radio on high power, but at this setting the waveform looked the best to me.
I also took the time to go in and properly set the driver/final bias voltages per alignment instructions. The voltages were a little high from whoever was in the radio before me. IIRC, I set the driver bias at 3.60V and each final's bias to 3.80V. These are MOSFET finals, do these voltages seem right?
