Try setting MODE to AUTO, SOURCE to LINE, and one of the trigger modes to vert.
Also select NON Store at the top row of 4 buttons.
Those three ports are for an X-Y Plotter. That must have been used in a high technology engineering lab. The back of that unit looks wrinkled from heat.I also have these ports and switches on the back of it
Yes I think you have some fried parts in that scope. I hope you did not pay too much for it.This thing may be burned up do to this damage
Actually that would be a failure of the time base generator sweep output.If the dot at the center of the screen just won't respond to any of the position controls, I would suspect a power supply failure.
