Common problem the amp stays keyed after you unkey the radio because it starts self-oscillating.
Some of them you could get away with cutting the Inductors grounding the bias and adding negative feedback across the transistors cleans them up some.
Not taking shortcuts would be like the Magnum or Cobra amps that were built with electronic adjustable bias with thermal tracking and some filtering on the output.
They are what they are, CB amps.
Most like the old gray amps had no bias at all because as long as they worked, the builder spent no time or additional parts to make them better, why?
It cost them more to build and no one cared.
This is why solid state ham amps cost big $$$ and CB amps are relatively cheap, they are properly built with adjustable bias, high SWR shutdown, over drive protection, band pass filtering, overheat protection.
