Need some help with one of these RFX95HD amps on a superstar 3900 single final BJT.
Brand new RFX95HD,
Radio has no swing mods, limiters intact,
Replaced Final and driver cause of low output with just radio,
Got radio itself running great, 3w key swing to 25w peak,
Hook RFX up and automatically swings to about 75w peak,
Within 6 seconds swings drops to 50w peak, unkey for about 10 seconds, key up swings to 75w peak, 6 seconds later drops to 50w.
Unhook amp, radio itself doesn't drop power at all.
Driver bias set to 50ma, final set to 100ma, nothing gets hot in radio at all, amp gets quite warm but not hot enough to scream ouch.
I've checked and rechecked everything, nothing is wrong with radio or installation.
I did not touch the bias VR on the amp, it's setting at the halfway mark.
On SSB it dims the meter light a lot, amp meter on my power supply (set at 13.8v) jumps from 3a idle up to about 8a maybe 9a on deadkey of 5w and swings up to about 13a when modulating.
To me, sounds like the mosfet in the amp is shutting down for some reason.
Any advice is highly appreciated...
