I like these old PC66s and grab them up when they are cheap or "for parts".
This one has a channel mod that was installed improperly. It wouldn't transmit or receive when I first tried it out. The ground and input were reversed on the "switch/xtal" board to the add-on "tune board". After reversing these and cleaning up the switch contacts, I was able to transmit on all 4 "band" positions on the switch. Position C, was the 27 megahertz CB band which I'm most familiar with so I tuned that first. Band D continued with 27.415, I hadn't yet messed with bands A and B.
When I tried to tune receive, It wouldn't allow me to achieve peak on any coils without it dropping back down to nothing, like the AGC was killing everything even at -110dbm. I noticed that, for appeared to be the power supply wire for the add-on boards went to + of c-36 (measured 12v), and was probably milking power from the receiver. (???). I moved this wire to the switched side of the power switch, and was able to tune the CB band (C) in both transmit and receive absolutely perfectly, but now have nothing on A B and D.
Is anyone familiar with, or can recognize this "add-on board"?
I'm going to try moving that power wire to an 8 volt supply near the regulator, to see if it makes any difference, but I can't get back to this for another 3 days. It would just be cool to hop back into this thing with some extra insight.
Thanks guys, you've all been a great source of knowledge in the past!
