penetrator 500
You should consider converting it to a P500 by simply hand bending a T match from aluminum or copper 12gauge and drilling a single hole through the bottom insulator for the stud to feed the T match directly from the center of the coax connector.
It's really easy to do and you'll have a higher power handling antenna.
If the matcher that I built doesn't work, I'll give it a try. Thanks for the advice.
