Hi,
I'd like to be able to do a full alignment as described in the service manual for radios. I have been able to do the current alignment of the finals and driver with my multi-meter but seems like I need some more equipment to do things like receiver alignment properly.
As this is just a hobby and something I won't be doing all the time I'm not going to drop a load of money on expensive hardware so I'm looking to see what can be done relatively cheaply.
It seems like there are 4 things I need: Frequency Counter, Spectrum Analyser, RF Signal Generator, Oscilloscope. This is what I know and some links to devices which I think might work. Any feedback on the suitability of these would be great.
Frequency Counter: There are dedicated frequency counters available fairly cheaply. I assume these should be accurate even though they are cheap due to the way crystals work:
0.1-1100 MHz 0.1- 1.1 GHz Frequency Counter
DC 9-12V 1MHz-1.2GHz RF Frequency Counter
Spectrum Analyser: It seems like some of the new SDR USB dongles can be used as a Spectrum Analyser. They have a range starting at 25MHz and can do all of HF with an up converter:
Nooelec NESDR Smart v4
RF Signal Generator: This one I am not too sure of where to start. Possibly an SDR tranceiver would do it? What are the requirements for a Signal Generator when doing alignments?
Oscilloscope: There are affordable USB oscilloscopes available. The cheaper ones only have 20MHz bandwidth which I'm assuming isn't enough to cover 11 meters. The more expensive ones have 50MHz bandwidth. I understand that USB oscilloscopes tend to be a bit noisy but would this be sufficient?
Hantek 6052BE PC USB Oscilloscope
Also are there any tutorials on the process for doing an alignment on a radio which are a bit more user friendly that the very concise details found in a radio service manual? So far I've found the TRXBench youtube channel very helpful.
Thanks
Thanks
