What size Power Supply should I use to Run this Polamar250.I will be useing it with a Uniden Washington Base?
id use a 30 amp atleast a 250 amp will spike 25 to 30 depending how you drive itWhat size Power Supply should I use to Run this Polamar250.I will be useing it with a Uniden Washington Base?
