Both came in at the same s-units but the monkey definetly had a lot more audio, it was louder and cleaner than the 8.5' steel whip.
Decent? over the Monkey made?Predator 10-K makes a decent lightweight antenna.
I totally agree, although I'm not sure how marks name came into this.Decent? over the Monkey made?
The single coil Predator is over a foot longer than the Monkey made. On mobile antennas, the closer it is to a full 1/4 wavelength of it's designed frequency the less loading coil is needed resulting in less inductive coil losses that are inherent with loaded antennas.
There is nothing magical about any of these center loaded metal CB antennas regardless of what Mark Sherman says.
A cheap 4ft. fiberglass whip properly mounted on a good location such as you did on your Tahoe will make more of a difference than a high power handling steel coil antenna mounted in a poor location.
