For VHF/UHF, the TRAM 1181 with a Nagoya Ground plane kit is widebanded enough to cover 2M Ham, MURS. 70cm, FRS/GMRS
cool ! What about cb?
I'll try to get a couple photos this evening... here is one I have available...
It is actually a "Aircraft Flare Can" same width/height as a 50 cal can, but about 3" deeperis that a 50 cal box?
I was thinking of using a president cb for this project. Plus a gmrs and a spot for ham if / when I get my license.Base or Mobile?
For reference, this is the same size can with B-Tech 25x4 and a 12v/30a power supplyView attachment 40287 View attachment 40287
I’ve been playing around with box layout and was wondering if I could get your feedback on this version?
Any products you think which are unnecessary or redundant? or perhaps there’s a better version of a product I should use? How about Air flow design? Power vs rf separation?
thanks!
i built a solar generator back in 2007.Has anyone built a home brew radio/ battery / solar charge / dc power supply case?
I’m thinking of building a radio in ammo can type setup but could use some help with products / design “gotchas” to get started
any lessons learned you all have would be good to hear!
