I currently have a 5' fiberglass K40 antenna on the bed rail of my F150. I have it mounted about 2 feet behind the edge of the cab and more than half of the antenna is sticking up above the cab.
I have been thinking of getting a magnet mount antenna base load antenna to put on top of the cab instead (K40 or Wilson probably, not sure which yet).
Here is the reason why: In order for the antenna to tune, I had to run a ground from the mount to the frame. I did this in 2 short sections. One from the mount to the tie down point in the bed, then from there to the frame. I am getting alot of noise from the fuel pump.
I wasn't sure if going to a magnet mount on the roof would help any of that noise, plus wasn't sure if mounting it higher like that would help my tx/rx any, if at all.
Thanks
Thanks
