I am trying to get the voltage down on an unregulated power supply.....it is frying pills because it is doing 22 volts at key up and goes down only to 16.
I have tried using a five watt resistor of different values both on the ac side(pri and sec) and dc side.....could some give me some direction??????????????
I have noticed that the voltage always goes up after going through the diode rectifier.
I am using two four pin rectifiers with a resistor and cap across the dc pins.
I would be willing to help anyone build your own power supply ......just let me get this last problem figured out. I have one that is 125-150 amps using two large transformers and a bank of caps..
oh yea this amp has two 2879's.
thanks ,
davis
thanks ,
davis
