POWER SUPPLY TO RUN HF
The Cosel PBA1500F-12 1500 W Watt, Single Output, 12 V@125 A General Purpose Enclosed with Fan AC-DC Power Supply is a nice unit if you can find one on eBay for cheap.
I just saw one on eBay the other day for a couple hundred dollars
  • @ Geoexplorer69:
  • @ Geoexplorer69:
